Toslink or Digital Coax?
Discussion in 'Archived Threads 2001-2004' started by Shion_ca, Oct 11, 2002.
  1. Shion_ca
    Shion_ca Stunt Coordinator
    Aug 17, 2002
    89
    I have the option of either from my Pioneer DVD 440 to HK320. Which is the better way to run digital? How do you guys do it and why?
    Shawn
  2. Kimo Bonnelycke
    Kimo Bonnelycke Stunt Coordinator
    Feb 1, 1999
    98
    Hi Shawn,
    In my experience, you will not notice a difference. The real question you should be asking yourself is, do you have other deivces that have only coax, or only optical. Myself, I have switched many times between coax and optical on my dvd player, and I never noticed a difference. I currently use coax, only becuase I have 3 other devices (sat, and 2 cd players) that have only optical, and I only have 3 optical inputs on my reciever. (and 1 coax of course).. Hope this helps.
    Kimo Bonnelycke
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
  4. Iver
    Iver Second Unit
    Sep 23, 2002
    324
    I use optical and I love it.
    Seriously, the above posts are correct. Optical and coaxial are two methods of carrying the digital datastream.
    Since both carry the same data, anybody who can hear a difference should share what they're smoking with the rest of the class.
    One practical tip: some optical cables come with a small, bump-shaped, clear plastic tip. This is a protective cover. Remove it before attempting to insert the optical cable into an optical jack.
  5. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    Optical, mainly because thats all my RP56 has. Also with Optical you won't get any EMI/RFI, that could happen with coax if not properly sheilded.
    Kevin
