Mike Veroukis
Greetings Toshiba fans!
I posted this on HomeTheaterSpot without a response and thought I'd ask here too.
I've got a 50HX70 with a manufactured date of Feb 2001. According to some on these forums this set may have the 3:2 pulldown problem that has been talked about. Well, I went out and bought the Cinema7 remote control and got the set into ADDR UPCON mode. However, when I went to 17FH I found the data value to be 07. Now this was a bit of a shock to me as I was sure that my set would have not been properly configured from the factory due to reports about the manufactured date AND the fact that I see absolutely no difference between DNR modes auto and off.
Is it possible the HX70's require a different value to be changed or the value to be changed to something else? Is it possible that the DNR circuit is not engaging? What could prevent it? I do NOT have a Progressive Scan DVD player. It's the lower end Yamaha DVD player (model # escapes me). The DVD player is hooked up via ColorStream HD1. What I've been using as a test for the 3:2 pulldown are the first space scenes in 2001: Space Odessy. As the space ships move there are severe jaggies along the edges creeping along. I believe the 3:2 pulldown should make a difference here, correct? From what I understand the 3:2 is supposed to smooth the jaggies along straight lines as they move across the screen, while stationary jaggies should be about the same. Perhaps I'm looking at the wrong effect?
If someone could let me know what to look for, that would be great. Are there other sure fire ways to test if the DNR mode is working properly at all? Should I try it in ColorStream HD2 or perhaps S-Video?
- Mike
- Mike
