Brian Mueller
Grip
- May 13, 2000
My old X81 was recently replaced under warranty with a new TW65H80, which is mostly a good thing. However, all of the menu changes are driving me nuts, and I was hoping someone could help me clarify a few things.
1) The X81 had a menu setting for the component inputs for DVD and DTV. This setting no longer exists with the H80, so I assume the set now figures it out (black level, etc. - whatever it changed before) automatically?
2) With the X81 the Theater mode turned off SVM, then you could adjust black level, white level, etc. in the service menu to get Theater mode where it should be. With the H80, Movie mode still turns off SVM from what I can tell, but the service menu parameters (sub-contrast, etc.) seem to have little affect on the picture and there is no service menu parameter for sharpness. Now, it SEEMS that if I first set Movie mode and then adjust the user controls that SVM stays off since I don't see the double-wide black bar on the test pattern, but I'm still not 100% sure of that. Can anybody confirm how this works? Since I just went through a long repair hassle I don't want to take any risks, so I'm not pulling the SVM connectors right now.
While I'm at it, does anyone have a favorite focus adjustment procedure for this set? I'll probably use the wooden block, clamp, and tracing paper setup I found on the Keohi site, but if anyone has a better one then I'll certainly give that a try.
- Brian
- Brian
