Toshiba vs Pioneer vs Mitsubishi
Discussion in 'Archived Threads 2001-2004' started by almel, Jan 22, 2002.
  1. almel
    almel Auditioning
    Jan 21, 2002
    3
    Well I think i have finally narrowed the field to these three possibilities...
    Toshiba 65hx81
    Pioneer sd-643hds
    Mitsubishi 65819
    Please comment about these sets and any others in the 3500.00 price range..
    I have heard good and bad things about each of these units...I would like some opinions from other owners and people in the know...
  2. DavidMich
    DavidMich Stunt Coordinator
    Nov 27, 2000
    177
    Hands down, the Pioneer is the better set. I don't know what problems you have heard about, but I assure you that whatever inherent "problems" that the Pioneer has, they are negligible compared to the other sets you mention.
    I was going throught the same quandry about which to purchase.
    Toshiba: Poorer build quality, and warranty issues.
    Ghosting and ringing
    Vertical banding issues
    Upconverts to 540p (they do this because it was
    easier....it is the same timing as 1080i (half)
    Marginal stretch modes and line doubling
    Mitsubishi: BAD Red Push
    Terrible line doubler...
    Lousy stretch modes for regular broadcast TV
    Pioneer: Best Line doubler in a RPTV
    No Ghosting/Ringing/vertical banding
    Best Stretch modes in a RPTV
    Best picture out of the box
    Best build quality/great warranty department
    This is purely my opinion.
    I would suggest checking out www.hometheaterspot.com and looking under the specific manufacturer fot detailed information.
    Remember, everyone compares all sets to the Pioneer Elite.It is the standard by which all RPTVs are judged. I don't think anyone will tell you there is a better picture in any set. The SD series from Pioneer are VIRTUALLY (that's the key word here) the same set. The differences are VERY minor in regards to the working parts.
  3. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    The Pioneer Almel is looking at is not the elite..It is the standard set...
  4. DavidMich
    Nov 27, 2000
    177
    Yes, I know. That is why I said the the differences are very minor. Most people will agree that the picture on the non-Elite is very comparable to the Elite.
