toshiba velocity scan modulation
Discussion in 'Archived Threads 2001-2004' started by John-Miles, Jul 13, 2002.
  1. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,216
    3
    110
    does it come on as a default?
    and if so can it be turned off without using the service menu?
    in particular im refering to the toshiba 36 HFX71
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Yes, it's switched on in the default viewing modes. My understanding is that SVM in Toshibas is defeatable in the "Theater" mode by reducing the so-called sharpness control to zero.
    Maybe someone else here can clarify that.
    (My bedroom set is a recent-vintage 27-inch Tosh, and it looks quite nice in "Theater" mode and with "sharpness" turned off.)
  3. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    I've read that the VSM is "off" by default in the "theater" mode. You can then adjust the other settings to suit your taste and that group of settings will be saved in the "preference" mode with VSM off.
    I don't know if this pertains to all Toshibas or just some, but that's the word on my 42H81 RPTV.
  4. John-Miles
    Nov 29, 2001
    1,216
    3
    110
    Thanks Jack and Jan
