Toshiba SD9200 Question (1 Viewer)
Chris DiPetta
I'm considering getting this unit. However, I want to hook up the optical or coax out for DD/DTS/CD, and the 5.1 analog for DVD-A.
Am I going to have to switch settings on a menu to change outputs, or will the 9200 output DVD-A on the analogs, and everything else on the digital outs?
Dave_Dunk
Yes,
and it's very annoying! You have to manually switch to 6 channel analog in the players setup to use the 5.1 outputs. ( I have a macro on my Denon remote to do this ). Silly really, because Toshiba could have quite easily had a button on the remote to toggle between 6ch / 2ch / bitstream. Still, great player....
Dave.
hickskeith007
