Shuvayu
- Oct 9, 2001
Hi,
I bought a toshiba sd 6200 dvd player about a year ago. I was genrally very satisfied with it until recently when, I started having scanning problems with some dvds. I have noticed the following problems:
(1) A dvd would not scan at all - the player kept saying that it was trying to load but never successfully loaded. In a first generation non-progressive scan Sony player the same dvd scanned immediately.
(2) A dvd scanned but the menu was unselectable, i.e. a "menu" came up with options like Song Selection/Chapter Selection/etc. but I couldn't select any of them. On pressing "Play" the dvd did not start playing. But instead, on pressing "Top Menu" in the remote, the movie started playing. Obviously, I did not have chapter scanning capability and so, had to resort to fwd/rev in the remote to scan the dvd. In a friends Sony lower-end player, the dvd menu just scanned fine.
Does anybody know of the sd 6200 having problems with certain dvds? Is there a firmware upgrade available to fix it? Toshiba does not say anything in their website about 6200 problems. Can anyone help me with suggestions?
-Shuvayu.
-Shuvayu.
