James_SCEA
- Sep 19, 2003
I just recently purchased this Toshiba SD5960 (200$)and was under the impression that it would output 720p or 1080i from the Component video outputs, not just the HDMI. Upon contacting the Tech Support team, they advised that it was HDMI only.
My Panasonic HD Tube has a DVI Input, and I found that Monster cable makes a HDMI to DVI Conversion cable (100$/1m). My question: Should I invest in a different player that outputs 1080i through the components or would this HDMI output be just as good as one that has a DVI output? I've heard that the DVI output on some players is not always as good as the 1080i Component out; is this true?
Thanks in advance,
JC
Thanks in advance,
JC
