Toshiba SD-4900 problem (blank screen w/ Progressive Scan)
Discussion in 'Playback Devices' started by Alf S, Jan 12, 2004.
  1. Alf S
    Alf S Banned
    BANNED
    Apr 23, 2000
    3,477
    621
    4,110
    Alfer
    Hello all,
    I have a friend who bought this DVD player and when he set it up, he clicked "Progressive Scan On" (turns out his TV only has S-Video) and the screen went black.
    Now he can't even see the menu system to turn progressive scan "OFF". He unplugged it for 30 minutes, and plugged it back in..still black screen. Can't play anything ..nothin.
    Any ideas what he can do to reset it or get out of Progressive mode if he can't see a menu screen?
    Thanks!
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Take it to a store, hook it up, change it back....
    Most palyers give a massive warning when doing this switch telling you, it will disable the current input.
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    You cannot get progressive via s-video. You will have to hook it to another TV that has component and is HD capable, (which his TV is not since it does not have HD inputs) to correct the setting.
  4. Bill_Mis
    Bill_Mis Stunt Coordinator
    Dec 12, 2000
    63
    I have the 4800 Toshiba and on the rear of the machine there is a switch between Interlaced and Progressive. Just be sure that its placed in Interlaced if the tv is not compatible to safeguard against this happening again. After you unplug the unit and move the switch, plug it back in and you should be back in interlaced. Don't bother hauling it back to the store.
  5. Alf S
    Alf S Banned
    BANNED
    Apr 23, 2000
    3,477
    621
    4,110
    Alfer
    Thanks for the info folks...I have passed it on to my buddy.
  6. Alf S
    Alf S Banned
    BANNED
    Apr 23, 2000
    3,477
    621
    4,110
    Alfer
    FYI
    Per Toshiba, this is the fix for the problem mentioned in my post:
    "Remove the disc from the player, close the tray. Now press the stop button twice, then hold it down for 5 seconds." I did, and BAM I had the Toshi welcome screen."
    Worked like a charm.
  7. John S
    John S Producer
    Nov 4, 2003
    5,460
    I figured Tosh had a way around it.
    Many real cheapo players have no way around it though.
