StephenWhitaker
- Dec 30, 2002
Hi,
I have a Toshiba 40X81 16:9 rear projection tv and until recently used it a Toshiba 2109 DVD player. Lately however, I purchased a Toshiba SD-3800 progressive scan DVD player but have been horribly unimpressed. From what I see the black level is not right, and there is definite detail loss. I really hope it's a configuration problem.
With the 2109 the picture quality had been very good ( I guess I couldn't notice any deinterlacing artifacts, potentially I don't know what they are). Anyway, assuming that a progressive scan dvd player would remove most deinterlacing artifacts and produce a slightly crisper picture, I purchased the SD-3800. Sadly, I did this before doing enough research (chroma upscaling etc).
I have tried to find the black-level adjustment for the SD-3800 but was unable. Can someone tell me how to adjust the black level? What I notice is that in progressive mode, the blacks are more like dark grey, I assume that setting the black level can help fix this problem?
However, my guess is, even if I fix the black-level but still see a loss in detail, I'm going to have to return the player and continue to use the 2109 until I find a player (such as a Panasonic) which will provide the experience I suspect.
Thank you for any help or experience you may have had with a similar setup.
Steve
Steve
