JasonRH
- Jan 8, 2001
I have the Toshiba 32HFX72 direct view and when there is a red object/menu (anything with a uniform red field) displayed on the screen there are lines that go through the object like the picture is exhibiting some kind of noise. A friend has the same problem on his Hitachi RPTV. Red is the only color that shows this distortion. Any ideas on what the problem is and if it can be fixed/reduced?? Thanks a lot.
