Les Holt
- Oct 3, 1998
The Toshiba DST3000 HD tuner arrived from One Call today, and here's a brief report. (I do not have Direct TV at this time, so I'm only evaluating the OTA digital TV performance, not the satellite performance.)
I prefer the unit to the RCA DTC-100 for the following reasons:
1.Better performance under multipath conditions. The Toshiba allows me to receive an additional channel that could not be received with the RCA, and also gets a cleaner lock on the existing channels. Not a day and night difference, but enough to be important to me. I'm in a very hilly region in the East San Francisco Bay Area and don't have clear line of site to any of the digital transmitters, which are 40 to 45 miles distant. Multipath performance is therefore the most important criterion to me, and the Tosh wins.
2.No fan noise. The RCA fan drove me nuts with its whining fan that constantly changes pitch. The Toshiba has no fan noise - I don't believe it has a fan at all. It has lots of ventilation holes in the cover.
3.Smaller, lighter, neater. If appearance counts, the Tosh wins handily over the ugly RCA.
4.The Toshiba can accept two OTA antennas (although perhaps not two OTA antennas plus satellite - I don't have this configuration so I can't report on it for sure). One can enter the menu to switch the active physical input from one input jack to the other. Thus, even though one jack is labeled "Satellite," it can function as an OTA input. However, unlike the RCA, the Tosh does not have two antenna inputs and one satellite input (three physical inputs total). However, it appears that the two jacks on the Tosh can be configured as virtual jacks to perform the desired function (though not two of the same type at the same virtual time - one has to use the menu to switch the jack function. This means that instead of one keystroke to switch antenna inputs, several keystrokes are required through nested menus).
5.The tuner on the Tosh is more sensitive than the RCA and better at pulling out weak analog signals. The Tosh is on a par with my other tuners - the RCA was way below in performance.
6.Analog OTA signals look much better on the Tosh - they don't have that "washed out" look that the RCA is famous for.
7.There are no 1080i HD broadcast during the day, so I can't report on the relative image quality of the Tosh and RCA in HD. From all appearances (a couple of good-looking commercials), the Tosh should be at least equal to the RCA, if not better.
8.The menu response appears faster on the Tosh than the RCA.
In sum, my initial impression is that the Toshiba DST3000 is a winner. I'll have more to say with more time.
Les
Les
