Toshiba CW34X92 Problem
Discussion in 'Archived Threads 2001-2004' started by Brian Boudreau, Nov 30, 2002.
  1. Brian Boudreau
    Brian Boudreau Auditioning
    Nov 30, 2002
    2
    I recently took my Toshiba CW34X92 16:9 HDTV out of storage where it had been for a few months. Since then the TV has shadowing around the 4 corners of the screen. Is there a way to fix this? Could this be burn in? I plan on having the set ISF calibrated could this clear the problem up?
    Brian
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Describe this "shadowing" phenomenon in a little more detail. Are you saying the four corners look darker than the rest of the picture?
  3. Brian Boudreau
    Nov 30, 2002
    2
    Yes, the right bottom corner has a dark greenish spot that one is the most noticable, it is about the size of a golf ball. The other 3 corners have some dark shadowing that is only present in the sides and corners. I can take a picture of it if you'd like. I am not sure if it is "burn in" I am very careful with my set and I am not sure what could have caused this. Could it need to be "degaused"? Thanks for your help.
    -Brian
