Toshiba 62HM95 : PC connection compatibility?
Discussion in 'Displays' started by Alex Baxter, Dec 1, 2005.
  1. Alex Baxter
    Alex Baxter Auditioning
    Dec 1, 2005
    2
    Hi all,
    My fraternity recently purchased a Toshiba 62HM95 (DLP) and have in general been very happy with its performance. However, we need to connect a PC to it (briefly at least) later in the year. In the owner's manual, there is a warning symbol four times or so on the different inputs saying "Note: never connect this TV to a personal Computer. This TV is not intended for use with a PC." The warning appears on the firewire and HDMI input pages specifically and once in general (not specifically on S-vid or composite).
    So my question is: do I believe the owner's manual? The guys down at Best Buy said that it shouldn't be a big deal, hooking in a PC for a little while. I called Toshiba and the rep was rather unhelpful, only suggesting it was a burn-in problem after I prompted him about it, saying that they have a seperate TV that is inteded for use as a monitor. I can't see how plugging a computer in to S-video is somehow different from having a gamecube plugged in there, and if we are careful about preventing burn-in, I don't know how there will be a problem.
    Am I missing something here? Or should I feel free to plug in a PC if I turn down my contrast and be sure not to leave a start menu there for hours on end?
    Alex
  2. Jimi C
    Jimi C Screenwriter
    Feb 22, 2004
    1,209
    I thought DLP was immune to burn in? ITs just a series of tiny mirriors that move to reflect light through a spinning color wheel. I thought anyways. My DLP front projector has 2 VGA ins that are labled COmputer 1 and Computer 2.
  3. Alex Baxter
    Dec 1, 2005
    2
    Unfortunately the model with actual VGA/DVI input was $500-800 more for the same size =. As a collorary, is it possible to change from VGA to HDMI with an adapter?
  4. Dick Knisely
    Dick Knisely Second Unit
    Oct 22, 2005
    372
    Hmmm... you made me go look and my Panny plasma has a similar warning. Hadn't thought about it but what the heck is with that? PC has a DVI output and TV has an HDMI input -- just need the adapter to connect. Am I missing something, too, or are the manufacturers just being coy about what you can really do or?
  5. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Plasma sets are susceptible to burn-in, though newer ones aren't nearly as bad. DLP, LCD, and LCOS sets are not susceptible to burn in.
