Toshiba 57HX81 convergence grid allignment question
Discussion in 'Archived Threads 2001-2004' started by Doug_JC, Dec 15, 2001.
  1. Doug_JC
    Doug_JC Extra
    Sep 8, 2001
    22
    Today I measured where the verticle centerline of the convergence grid is and found it was shifted 7-8mm to the right. The dimensions of the screen are 1261mm x 709mm so the verticle centerline should be at 630.5, but it was only 623mm from the right side.
    I have tried WID and HPOS in the service menu but they do not move the grid. Does anyone know how to do it?
  2. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    Try VCEN
  3. Doug_JC
    Doug_JC Extra
    Sep 8, 2001
    22
    I forget to list VCEN in my post. VCEN did not change the position of the convergence grid either.
  4. Eric Samonte
    Mar 31, 1999
    1,318
    I guess u have tried everything because that's about it, VCEN, VPOS, WID and HPOS. Sorry if I wasn't any help. But I know that I have moved the whole grid thing using these parameters when I did the overlay.
  5. StephenMSmith
    StephenMSmith Stunt Coordinator
    Apr 29, 1999
    85
    There is a parameter to move the whole grid horizontally in the designer menu, but the designer menu is no longer available to the public.
    But you still have 2 options:
    1) use the centering magnets on the yokes
    2) just pull all the grid lines to the left in the service convergence.
    Steve
  6. Doug_JC
    Doug_JC Extra
    Sep 8, 2001
    22
    I wasnt thinking straight on this one. I went ahead and shifted all the convergence lines left about 1/2 inch to get it lined up correctly. For now I just measured and used strings to get it close. Thanks for the help.
