Toshiba 50HX70..fast action
Discussion in 'Archived Threads 2001-2004' started by RossB, Nov 16, 2001.
  1. RossB
    RossB Extra
    Nov 8, 2001
    21
    For my home entertainment system I have a Toshiba 5 disk DVD (the model escapes me), a Harmon Kardon AVR510 and a Toshiba 50HX70 (plus some other stuff naturally). It is about 10 months old and is a great system except...on some DVD's the movement is sometimes distorted. It is almost like being on good drugs in that as a figure moves it kind of leaves a trail...sort of like several frames are showing at once.
    This has occured since it was new, and the dealer exchanged the DVD players (didn't help). I moved to the second color stream inputs which clears it up a bit...but it still happens. Has anyone had a similiar problem, or can anyone suggest what might cause this?
  2. Jeff D.
    Jeff D. Supporting Actor
    Jul 10, 1999
    521
    Jeff
    I have seen this artifact myself. Would the player happen to be the SD-3205? This was noted only if the TV's DNR control was turned to AUTO. Try turning it OFF. In my case, that eliminated the problem.
    Jeff
    "They're coming to get you Barbara..."
  3. RossB
    RossB Extra
    Nov 8, 2001
    21
    yes and yes. I have change the setting and will check it out. thanks for the tip!!
