Toshiba 50H82 help needed
Discussion in 'Displays' started by Ed*S, May 27, 2005.
  1. Ed*S
    Ed*S Auditioning
    Aug 19, 2004
    4
    I have a Toshiba 50H82 and something strange has happened. I normally watch everything with the screen size set to full. I assume this is the best mode as the others show too much stretch, or cut off at the top/bottom. Now, I can't select "full" which is option 4 I think on the screen size menu. It is greyed out and the cusrsor skips over it. I can select any mode but that one.
    What have I done? And how can I get this back? I'm using a HD DirecTivo if that makes any difference.
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Well, FULL mode does not exist if you are using an HD signal type.
    Go to a 480i or p type signal and Full should come back.
    Regards
