Calibration numbers from other TV's will probably not help because every TV is different (even those that are the same model) and every room has different lighting, wall color, background color etc. Other's settings may get you close, but then again it may be way off for your particular set in your particular room. The best way to calibrate is to get a copy of Avia, S&V or Video Essentials and perform the calibration using those.
