Shawn Sefranek
- Sep 30, 1998
I have a relatively small dedicated Theater Room that is only about 11ft wide & 13ft lg.
Even if I sit very close to the back wall, after subtracting the depth of the TV it ends up being about 9-10 FT from my nose to the screen.
I currently have a Mitsubishi 35” Diamond Line tube as a display.
I’m looking to replace it with a 16:9 RPTV.
I was all set on the Mitsu 46”, but now Toshiba comes out with the 50” 16:9 which might work for me.
I already have a Progressive DVD (Sony 700p) and the room is used 95% for movie watching so I’m not too concerned what CABLE TV or 4:3 viewing looks like.
I know there are a few NUTS out there sitting 6FT away from 65” sets, but that’s on the extreme side.
Am I shooting for too big of a set or do you think this will work out??
Shawn S
Shawn S
