Toshiba 40H80 problems, please help
Discussion in 'Archived Threads 2001-2004' started by MikeF, Nov 5, 2002.
  1. MikeF
    MikeF Stunt Coordinator
    Oct 17, 2000
    176
    Hi there. This evening, while watching TV on my 40H80, the display suddenly went dead. In fact, the TV may have powered off -- in any event, within a few seconds, I had turned it back on (or it remained on), with audio only (i.e. a blank screen). I turned the TV off, and after 5 minutes, turned it back on. The display was initially very bright and lacking in color balance; it went completely back to normal within 10 or 15 seconds, except now there are faint, wavy lines all over my screen, particularly visible against a black background.
    Any idea what the cause might be and whether I can expect it to improve on its own?
  2. Brian Glaeske
    Brian Glaeske Stunt Coordinator
    Jun 22, 1999
    94
  3. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    I had a similar problem with my 8-year-old Mitsubishi 35" direct view. After a couple of visits from a tech who spent several hours testing each capacitor, etc., and replacing some, he finally threw up his hands and said that he couldn't fix it. He suggested that a Mits repair station might be able to replace the motherboard for $500 or so, but on an 8-year-old set, I decided to set it out on the curb instead.
    I really expect a direct view set to last more than 8 years, so I was pretty disappointed, although I've had good experience with other Mitsubishi electronics.
    All I can do is wish you luck.
    Jan
