toshiba 36HFX72 pincushion help
Discussion in 'Archived Threads 2001-2004' started by John Kirkpatric, Jan 11, 2003.
  1. John Kirkpatric
    Dec 1, 2002
    18
    Never noticed it until I got stupid and bought one of those video calibration DVD's. Is this a downfall of flatscreen technology or is there an adjustment? (nothing in the manual). The top and bottom "black bars" seem to be bowed quite a bit. Appreciate any suggestions.
  2. JasonRH
    JasonRH Second Unit
    Jan 8, 2001
    496
    John,
    Geometry problems plague flat screen sets. It is possible to get one that is very good out of the box but it's sort of a crap shoot. That being said, there may be some service menu settings that can help reduce the bowing on your set but I don't have the info handy. A Toshiba tech may have the info you need and can probably tweak it for you. Give the service center a call.
  3. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,210
    Like Jason said you just ahve to adjust the geometry in the service menu, i know i had to do some adjustments to my 36HFX71, but now it looks great, though i do have a slight bowing.... but its not very noticable.
  4. John Kirkpatric
    Dec 1, 2002
    18
    Thanks for the reply but maybe I'm missing something. Is the Service Menu readily accessible? When I check all the menu's, the only option I have is "tilt". Is there a separate menu somewhere?
  5. John-Miles
    Nov 29, 2001
    1,210
    The service menu is just that, a special menu for a service technician.Technically speaking entering the service menu will void your warranty, but then as some people say how will they tell if you have entered your service menu?
    I have some of the parameters and how to enter the service menu for the HFX71 model, e-mail me and i can send them to you, but there is no gurantee that they are the same for the 72 model.
    also any work done in the service menu must be done VERY carefully
    only mess with the parameters you know, and many many other guidelines. also write down where everythign was to begin with that way you can return to where you were if you mess up.
  6. John Kirkpatric
    Dec 1, 2002
    18
    Hey John. Could you please send me the details? Thanks,
    [email protected]
  7. John-Miles
    Nov 29, 2001
    1,210
    I e-mailed it to you the other day, did you get it?
  8. John Kirkpatric
    Dec 1, 2002
    18
    Oops, I got them. Didn't think to check yahoo. Thanks.
  9. John-Miles
    Nov 29, 2001
    1,210
    No Problem John, like i said if you have any question just ask. I have a fair bit if experience with the geometry settings on my tv, although I am no where enar as experienced as alot of other people here [​IMG]
