Toshiba 34inch widescreen Model 34HF85C any good? Update on Advent WS TV?
Discussion in 'Displays' started by kuliddar, Aug 16, 2006.
  1. kuliddar
    kuliddar Agent
    Sep 25, 2004
    32
    Hi all,
    Looking into a 34inch widescreen crt. Is the Toshiba Model 34HF85C any good. Also does it have an HDMI input as I can't find it in the specs given to me.
    Anyone have an update on the Advent 34" Widescreen TV. I can't find reviews anywhere on it.
    Thx guys
  2. kuliddar
    kuliddar Agent
    Sep 25, 2004
    32
    Ok well I found out about the advent. No HDMI on that one, just DVI. So scrap that. Just need the info on the Toshiba now.
  3. dan-0
    dan-0 Stunt Coordinator
    Aug 1, 2003
    156
    I have a newer Toshiba 34" with HDMI. There are some issures with this set, not just mine but all of them, however, they can be worked around. I'm quite pleased with it. As everyone knows, you can get no better hi-def picture then that of one from a good 'ol CRT.
  4. kuliddar
    kuliddar Agent
    Sep 25, 2004
    32
    What kind of problems in are there. What is the newer toshiba model number?
