Toshiba 34HF81 advice
Discussion in 'Archived Threads 2001-2004' started by Marlon, Mar 10, 2002.
  1. Marlon
    Marlon Agent
    Feb 1, 2000
    32
    I have the opportunity to buy the toshiba 34HF81 for about $2k. What is the consensus on this product? Should I go for it, or select another product.
    Thanks for the advice.
    marlon
  2. Marlon
    Marlon Agent
    Feb 1, 2000
    32
    Am I to assume that no one has had any experience with this product?
  3. Victor Y
    Victor Y Agent
    Jan 15, 2002
    35
    Do a search and you will find the infos you need.
  4. William_K_F
    William_K_F Agent
    Feb 4, 2002
    33
    I'd go for it, I got mine new for $2,300, so your price is very good. I like the set, like the prior person said, you can find out a bunch by searching here and at http://www.avsforum.com
    -William
