Toshiba 32AFX61 or Sony KV32FV27?
Discussion in 'Archived Threads 2001-2004' started by Diana M, Mar 11, 2002.
  1. Diana M
    Diana M Agent
    Jun 30, 1997
    37
    I'm having trouble deciding between these 2 sets
    I like the sound of the Toshiba (it has the new cyclone bass and 33 total watts of power), and I don't plan on hooking up speakers any time soon, as this is not our main set
    I like the darker cabinet of the Sony and the ability of the set to do 16:9 auto, and we watch a lot of dvds
    I have not viewed the sets side by side long enough to determine picture quality, they both seem to have a nice picture, with the Sony having the edge on a little more info on the sides
    Price is not an issue as they are only $100 apart
    Any input on either set would be very helpfull
    Diana
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    You need the 16:9 mode, so that pretty much answers the question, in my view. The Toshiba, though, has more accurate color out of the box. My WEGA, even in the "Warm" color-temp setting, is a bit too blue-tinted (i.e., hot) to be truly accurate.
  3. Tom Weeks
    Tom Weeks Stunt Coordinator
    Aug 23, 2001
    73
    I have both of these tv's (although in different sizes, Sony 27 in., Toshiba 36 in.). There is absolutely no comparison, the Toshiba simply blows the Sony away. I hear alot of rhetoric about the Sony 16:9, which is semi-valid. All other things aside, however, the Toshiba outperforms the Sony in every detail. Mush better and easier to dial in picture, FAR superior sound system, many more inputs. I already had my Sony when I went shopping for my 36in. and now (having had them both home for comparison)I am very glad I chose the Toshiba.
  4. Steve WC
    Steve WC Stunt Coordinator
    Dec 15, 2001
    180
    I am on my second 32fv27. Bad geometry on both but second not nearly as bad.
    Would not buy another Sony and my next TV will probably be RPTV.
    I think all direct view flat screens have inherent problems as I once saw a JVC 802 with geometry so bad they had to remove it from the show room.
    Sometimes you can manually get other makes of Tv's to squeeze.
