Toshiba 32" TV: What's the difference between service and design mode?
Discussion in 'Archived Threads 2001-2004' started by Sean Laughter, Dec 31, 2001.
  1. Sean Laughter
    Sean Laughter Screenwriter
    Aug 3, 1999
    1,384
    110
    I have the service manual for my Toshiba 32A40 (actually it says 32A50 on the manual but same TV I guess). Anyway, I'm just wondering what the difference is between the "Service" mode and the "Design" mode, and which one I should use when calibrating the setting using AVIA.
    When I first got the TV I calibrated using the regular user menus, but now that I have a chance to sit down and do it right I want to set all those menus to the center and make the adjustments in the service menu. I'm just not sure what the difference is between the service menu and the design menu and which I should be using. Thanks guys.
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    It makes no difference what mode ... anything you do in service mode carries through on the design side.
    Ideally ... use design for more customizing work ...
    Regards
  3. Luis Gabriel Gerena
    Luis Gabriel Gerena Second Unit
    Jul 18, 2000
    410
    What you have are more options in the desginer mode. You'll find parameters there that aren't avalaible on the service menu and are useful if you want to tweak deeper.
  4. Sean Laughter
    Aug 3, 1999
    1,384
    110
    Thanks guys.
