Toshiba 2710 has a 24-bit/192kHz audio digital-to-analog converter
Discussion in 'Archived Threads 2001-2004' started by PascalC, Aug 5, 2001.
  1. PascalC
    PascalC Agent
    Jul 24, 2001
    31
    I just bought a Toshiba 2710 which has a 24-bit/192kHz audio digital-to-analog converter. I see that most DVD players have 24-bit/96kHz audio converters.
    Now I look for a receiver who accept 24/192 analog signal
    Do you know if that exists?
    Can I take a receiver with 24/96?
    It will correctly decode through?
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    I'm not familiar with the Toshiba SD-2710.
    If this player isn't a DVD-Audio player, there's no material to playback that's 24bit/192KHz, so the DACs in the DVD Player would be overkill.
    No DVD Player can currently send a 24bit/192kHz signal digitally.
    For analog output, you'd want a receiver with analog bypass (also called direct mode on some receivers).
    John Kotches
    Contributing Writer
    Secrets of Home Theater and High Fidelity
