Tosh 65H81 issue
Discussion in 'Archived Threads 2001-2004' started by Neil Middlemiss, Nov 29, 2001.
  1. Neil Middlemiss
    Neil Middlemiss Producer
    Nov 15, 2001
    3,666
    1,111
    4,110
    Neil Middlemiss
    The black bar at the top of the screen on an anamorphic 2.31:1 disc curves up slightly on the right hand side? Any ideas what this is and if it can be corrected???
    Neil
  2. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    HI,
    This is not a black bar problem but a geometry problem and is correctable via the service menu which is meant for service techs and not tweekers [​IMG].
    Gregg
  3. Gregg Loewen
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    PS:
    A simple solution that will cost less than $10 is making some black mattes to cover the letterboxing. It is a great tweak too.
    Gregg
  4. Neil Middlemiss
    Nov 15, 2001
    3,666
    1,111
    4,110
    Neil Middlemiss
    So I should call someone to come and correct?
  5. Gregg Loewen
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    HI!
    If it is truly "slightly" a service tech wont touch it and will just say "its within specs".
    YOu can give it a go on your own, its not that hard to do. Check out this site:
    http://www.keohi.com/keohihdtv/index.htm
    Go to the Tosh area and look for geometry instructions.
    Lots of luck,
    Gregg
  6. Andrew Beacom
    Andrew Beacom Supporting Actor
    Jan 11, 2001
    792
    It's a geometry issue. Fortunately in an RPTV you can fix this. I fixed mine up by making a convergance grid overlay and converging to the grid.
    You have probably seen the 9 point user convergance option in the menu's. There is also a 56 point conversion in the service menu that many owners use to get their convergance and geometry as accurate as possible. You might also want to check the Toshiba forum at www.hometheatersport.com
  7. Brian Schucher
    Brian Schucher Supporting Actor
    Nov 22, 2000
    700
    It absolutely is something that even the novice tweeker can handle and fix. I did it with no probs.. Check the Toshiba Tweaks section at the SPot. The 56pt convergence will fix that right up...Just be aware that you DO need to be VERY careful in that service menu..
