Tools and parts needed (9 pics)
Discussion in 'Home Theater Projects' started by Jonathan T, Jul 17, 2004.
  1. Jonathan T
    Jonathan T Second Unit
    Nov 6, 2002
    360
    I will be ordering some Adire Audio 12.1s within the next month. I need recomendations on the proper tools and parts I need to build the speakers and set them up properly. What, kind of wood does adire recomend? Do I need a multimeter, and if so, which one should I get? What about solder and an iron? What kind of speaker wire? What kind of DB meter?
    Also, of these two rooms, which would probably be the best to put the speakers in? I know you can't tell exactly from just pics, but I'm sure some of you experienced guys could at least point me in the right direction.
    The Loft
    [​IMG]
    [​IMG]
    [​IMG]
    Living Room
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Sorry about the quality of some of these pics. I took them fast and at a low rez so they wouldn't take too long to load.
    Edit: the rooms will be cleaned up, boxes and clothes will be moved. The desk on the loft will also be moved.
    Edit2: One other question, what's teh difference between the first HE12.1 speakers and the Mark II?
  2. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    Nice pad!
    You have many questions and many of which you will learn as you go. Just buy the kit and plan out how you are going to tackle it one step at a time.
  3. Jonathan T
    Nov 6, 2002
    360
    Aright, but don't you think I should at least have an idea of what iron and solder is should buy?
  4. Andrew-_-_P
    Andrew-_-_P Auditioning
    Jun 30, 2004
    6
    I use a cheapo one from Radio Shack and it works fine.
  5. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    To answer your questions:
    - Not sure. However, most people use MDF to build the cabinets and baffles for the speakers. Then, they utilize some form of laminate or veneer to finish them off.
    - You might not need a multimeter - unless you need to check resistance, etc. for the crossovers. If that's the case, head for Radio Shack and pick up one of their meters. Should be more than adequate for your speaker building project - and any other projects around the home in the future.
    - Naturally, you'd use rosin-core solder. A simple 25 - 40 watt iron from Radio Shack should suffice. Personally, I hate the 25 watt irons because they barely get warm enough to melt the solder and tend to prefer the 40 watt versions.
    - 12 gauge wire from Home Depot. If you want to be neat on the inside of the cabinets, you could use the 12 gauge in-wall wiring that has a grey sheathing on it.
    - Analog meter from Radio Shack.
  6. Jonathan T
    Nov 6, 2002
    360
    I read through the particulars on Adire's website, they say that everything is matched and labeled, so I would only need a multimeter to see if the parts are good. I figure I can omit the multimeter.
    As far as finish goes, I was hoping for a wood that I could stain as I've heard applying veneer or laminate is difficult. Although, if I must go with MDF, I will.
    The guys at head-fi.com pointed me to either a cheep pencil weller iron or a used soldering station from Ebay. Neither will cost more than 40 dollars.
    Adire includes internal speaker wire so I will just get the 12 gauge stuff from HD
    thanks!
  7. Wayne Ernst
    Feb 24, 2002
    2,588
    If this will be your only soldering project, then just spend $7.50 and get one from Radio Shack.
  8. minhG
    minhG Stunt Coordinator
    May 6, 2004
    82
    most people use MDF because it is straight and cheap. I'm exaggerating a little, it's also acoustically dead and strong. but if the extra cost of real wood does not bother you then go for it. many people use baltic birch plywood, which is also recommended by adire over MDF.
  9. Jonathan T
    Nov 6, 2002
    360
    I had one of those things, it caught fire on it's own. I donno if I'm willing to buy one again. Not to mention the tip selection is non-existant and the tip that comes with the RC irons are fairly fat.
  10. Jonathan T
    Nov 6, 2002
    360
    I'll try that, thank you!
