TOC error on DVD
Discussion in 'DVD' started by Al_S, Sep 13, 2003.
  1. Al_S
    Al_S Second Unit
    Nov 30, 2000
    446
    Can a DVD with a TOC error be fixed? It just so happens to be on a DVD that is out of print.
  2. Adam_WM
    Adam_WM Screenwriter
    Oct 25, 2001
    1,628
    What's a TOC error?
  3. george kaplan
    george kaplan Executive Producer
    Mar 14, 2001
    13,063
    2
    It means table of contents.
    But to answer the question we'd need to know what specific error on what disc.
  4. Al_S
    Al_S Second Unit
    Nov 30, 2000
    446
    That's it to the error. That's all that shows up on my DVD player "TOC error." The DVD is a Tool DVD.
  5. george kaplan
    Mar 14, 2001
    13,063
    2
    I'd try a couple of things.
    One, make sure the disc is clean.
    Two, try it in another dvd player.
    If there's no dirt or scratches, and it won't play in any dvd player, there's probably not much you can do.
  6. Oleg
    Oleg Auditioning
    Jul 26, 2002
    13
    If the above doesn't work, try sticking it into a computer DVD drive and attempting to extract the data. It is a fairly involved process that's been made easier by some freely available tools and manuals. Since discussing the details of the extraction is probably against the forum rules (although the Tool dvd is out of print and, as far as I know, not replaceable) you should try googling for the subject.
