Pete Jennings
- Sep 13, 1999
I hate to rehash the age-old question of whether or not a 'Y" cable makes any difference on a sub's output, but I will.
After an exhaustive search, much online reading and a whole lot of soul searching I just bought a Velodyne SPL1200 sub from Onecall. I was originally going to choose between the SVS 20-29 PCI and the HSU VTF-3, but after Tom V. AND Dr. HSU kindly recommended placement in the same corner of my room, I realized that I couldn't comfortably fit the VTF-3 there (rear-ported), and that my understanding wife (who has been GREAT while I have been piecing together this system) REALLY didn't want the 20-29 in the corner of our great-room. So, after Onecall received another shipment of "factory re-manufactured" Velodyne SPL1200's, I figured that would be the best compromise for my situation and I pulled the trigger.
I received the sub in perfect condition, the only way you could tell it was a refurb was a slight screwdriver mark where they pried out the defective amp to replace it. I installed it in the recommended corner and calibrated it. So far I like it, I really don't think it was broken in by the previous owner before the amp failed, so it is gradually opening up for me.
I have used a spare three meter or so long RS Gold Series video cable to connect the SPL1200 to my Marantz SR-8200's only sub output. I am toying with the idea of using a "Y" splitter on the sub's stereo inputs. Onecall says Velodyne recommends it, but the only reference on Velo's website is to use it when you have auto on/off problems.
Am I right in thinking that *after* the sub is correctly calibrated, using a "Y" cable with the sub will have *no* output increase? How about increased sensitivity at lower volume levels? I have the sub temporarily plugged into the switched AC outlet on the back of my SR-8200, so I am not really concerned with the auto on/off. I will be purchasing a Panamax 5100 in a month or so, and will plug the SPL1200 into a switched outlet on the 5100 then.
I appreciate ANY information on this. When I grow up and build my next house with a media room, I WILL NOT let size dictate my choices!!!
Thanks!
Pete
Thanks!
Pete
