To spike or not to spike?
Discussion in 'Speakers & Subwoofers' started by EdNichols, Aug 6, 2003.
  1. EdNichols
    EdNichols Second Unit
    Feb 15, 2003
    372
    Right now my speakers are sitting directly on the carpet. I am getting ready to change from carpet to hardwood in my living room so I am wondering about needing spikes. I've lost the spikes for my speakers so I was wondering if it would be worth trying to get some replacement spikes. Do spikes make enough difference for me to try to get some more?
  2. Jonathan_E
    Jonathan_E Agent
    Jun 25, 2003
    43
    I'm pretty sure spikes are actually meant to be used with carpet, not hardwood floors.
    You want a nice solid base for your speakers so that they don't tip (If these are floorstanding loudspeakers, which I assume they are), so that is why you use the spikes with carpet because they poke through the carpet and make the speakers more stable.
    If you used spikes with hard wood floors, you'd just scratch up your new floor.
    -Jonathan
  3. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    I am a firm beleiver in the use of spikes, no matter what type of floor the speakers are on.
    The stability of a speaker is very important in how it sounds. Placing a speaker directly on a carpet will allow it to rock back and forth. As the woofer moves in and out, it causes the cabinet to move if the cabinet is not set to be stable. This (small) movement will affect the sound. I have tried it both ways over the years (with floorstanding and stand mounted bookshelves) and spikes always make a difference. Of course this is just my opinion. Probably some who would debate this.
    Also, many spike manufacturers include small discs to put under the spikes, to avoid damage to the floor.
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    How light were those speakers James?
  5. Dan Driscoll
    Dan Driscoll Supporting Actor
    Aug 1, 2000
    937
    2
    The bass response of most speakers will be reduced if they are placed directly on carpet or another soft surface. That's what spikes were originally designed for, to get speakers off carpet. But even sitting them directly on hardwood will interfer with how the speakers was intended to sound. Spikes (with discs to protect the floor) will decouple the speaker from the floor and help it sound more as the designers intended.
  6. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    I would not give spikes a second thought imo but do use a rubber pad.
  7. Arthur Vino
    Arthur Vino Stunt Coordinator
    Mar 13, 2003
    208
    Dan, thanks!!!
