Ken Woodrow
- Feb 12, 2001
My current HTPC configuration uses an Ultra160 Wide SCSI-3 setup with a Seagate Cheetah drive as the boot drive holding my OS and apps. Details of my configuration are here.
I'm about to make some hardware and software changes this weekend to streamline and stabilize the machine. It had become cluttered and unweildy after using it as my primary personal machine. Now that I've built a new machine for personal use, the HTPC can be dedicated to the theater.
So, my question is: should I remove the SCSI controller and drive and put it in my principal personal machine (an AMD Athlon 1 ghz) and establish a new boot partition on the IBM 60 gig drive? The computers are networked, so the loss of space on the IBM drive will not be missed, b/c I can access the drives on the office PC from the network.
One problem I've been having is heat -- both with respect to the CPU and the SCSI drive, which is sandwiched next to the floppy and the IDE drive. My goal is to be able to leave the machine on 24/7. It gets real hot when I run dScaler, which is CPU-intensive.
Will removing the SCSI drive help with the heat problem? Will I notice any loss in performance on home theater tasks, like DVD playback, dScaler, and music file playback?
Any input would be appreciated.
- Ken
- Ken
