Need some input/clarification from you SVS owners.
What I have will be a dedicated 13.5 x 20 Basement HT with the SVS SBS-01 7.1 driven by a 2600 yammy. The approximate cubic feet of the HT room would be 2025 with a four foot opening into a smaller 8 x 20 foot space that I will not be able to close off.
I have decided to "upgrade" the SBS-01 out of the gate either to a PB12-ISD/V or a 16-46 PCi, but I'm looking for some input on which upgrade to make. If it makes a difference since it is a dedicated HT little if any music will be played. I have read in several reviews that if the SBS-01 system has a so called "weakness" that it would be music but for me that would be almost a non-issue.
Looking for input and some owner feed back on advantages of Box or Cylinder Subs.
