Khai
Grip
- Jan 30, 2004
Hi,
Is there a way you can have the 'Loudness Contour' 'on' without it having an effect on the LFE channel - by that I mean that it doesn't boost the bass frequencies on the subwoofer channel as it does the front three channels?
The reason why I ask is that having experimented extensively between having the 'Loudness Contour' both on and off, I have found that on all accounts having the 'Loudness Contour' off, makes the bass noticably more cleaner, tighter and defined from the LFE channel. But, what you gain from a better LFE channel, you lose in the front three channels in terms of fullness and dynamics.
Surely there must be a way of having the Loudness Contour on without the processor giving a boost the the LFE channel?
