Tivo recording problems. Assistance Please.
Discussion in 'Playback Devices' started by Ronald Epstein, Sep 7, 2005.
  1. Ronald Epstein
    Ronald Epstein Founder
    47,703
    5,070
    I'm still sort of new to Tivo, but after owning
    a similar REPLAY unit for years before, I am very
    familiar with PVR technology.
    All of a sudden my Season Pass programs are no
    longer recording -- or at least I can't find them.
    Normally to find recorded programs I just go to
    the NOW PLAYING list and the recorded shows
    are listed at the very top.
    This is no longer the case. All I have in my
    NOW PLAYING directory is all the crap that
    Tivo recommends. I really wish I could get rid of
    the Tivo recommendations list.
    Just for the heck of it I did a SYSTEM TEST
    in the SETUP menu. The only thing that failed was
    the SAT IN SIGNAL, but all my channels are
    coming in perfectly.
    So I fail to see why Tivo is suddenly not recording
    Season Pass shows that it once did (I selected
    FIRST RUN and REPEATS). I may also be looking in
    the wrong area for the listed programs.
    Thanks for your assistance.
  2. Stephen Tu
    Stephen Tu Screenwriter
    Apr 26, 1999
    1,573
    -Is your To Do list populating?
    -Does the recording history at the top of the To Do list say anything about recordings you missed?
    -now playing, depending on what software version is on there, has various sorting & grouping options (hit "enter" or "display" depending on remote). You scrolled through the whole list & there are only suggestions?
    -try a reboot
    -you can turn off the suggestions under preferences. I like to leave them on since they occasionally find something interesting plus it functions as a rough free space indicator.
  3. Ronald Epstein
    47,703
    5,070
    Hi, Stephen!
    What seems to be happening (and your reply
    prompted me to push further to locate this) is
    that the recorded programs are pushed to the TOP
    of the LIST.
    It's ridiculously difficult for anyone who doesn't
    know better to find it because you have to scroll
    through pages of TIVO RECOMMENDATIONS to get to the
    actual list of shows you recorded.
    So, for the moment, I have found what I was looking
    for. Thanks for the help.
  4. Stephen Tu
    Apr 26, 1999
    1,573
    At some point you must have changed the default sort order, by hitting a numeric shortcut in now playing. By hitting enter or display you should be able to see options to change the sort order back to the way you want it.
  5. David Norman
    David Norman Producer
    Oct 12, 2001
    3,186
    447
    Takes a while to get through the menu, but on my Series 2 unit (the DirecTIVO's is a bit different, but th suggestion list can be turned off as well).
    1) Tivo Central
    2) Messages and Settings
    3) Settings
    4) Recording
    5) Tivo Suggestions
    6) No, dont record Tivo Suggestions
    I virtually never found anything I liked in their suggestions that I didn't already watch and I'd just as soon see only the things I asked the Unit to record -- no wading.
  6. Charlie Campisi
    Charlie Campisi Screenwriter
    Aug 20, 2004
    1,620
    43
    Ron, is your directivo the HD-tivo or SD? If it is SD, check to see if you already have the ver 6.2 software upgrade. The old version was 3.x. Your system info will have that for you somewhere.
    Anyway, the 6.2 software gives you the option of "folders" which you can use to organize your recorded programs, i.e., all the csi's will be together, all the Lost's, etc. It's really helpful for cutting down the number of pages you have to scroll through. Oh, and the 6.2 software is also much faster. Unfortunately, they haven't done the upgrade for the HD boxes yet. To activate folders, you just go into the now playing list, press "enter" and activate "groups."
    Here's another neat little tip -- press [​IMG] [​IMG] [​IMG] 7 8 from the Now Playing list will give you a nice split screen/preview pane with info about the show that is highlighted.
