Norman L
- Feb 19, 2002
Why do I lose PLII or Neo 6 when my cable box is connected to Tivo?
Can I bypass Tivo by splitting the cable?
Why do I lose PLII or Neo 6 when my cable box is connected to Tivo?First, make sure your cable box is in fact putting out stereo. Second, make sure your Tivo is recording stereo. It's under My Preferences->Audio Options. If it is, then one way to test if your Tivo is not recording stereo properly due to a weak signal from your cable box is to hook up a DVD player to the audio input jacks of the Tivo and start a manual recording. That should give you more clues as to where the problem is.
