Tivo add hard-drive?
Discussion in 'Playback Devices' started by Dave_Nich, Aug 27, 2003.
  1. Dave_Nich
    Dave_Nich Auditioning
    Aug 14, 2003
    12
    Is there a good web site that will describe how to add an additional hard drive to a Tivo Series 2 or a DirecTivo unit?
  2. WadeB
    WadeB Stunt Coordinator
    May 6, 2003
    231
    Don't know about the newer ones, but Home Theater Magazine ran an article about modifying the Phillips DSR 6000 unit a while back. I'll check my back issues and see if I can give you the month and year if you are interested.
  3. David Norman
    David Norman Producer
    Oct 12, 2001
    3,417
    564
    4,110
    Hard Drive Upgrade
    I think this site is the best. I upgraded a regular Philips DirecTivo without a hitch -- added a 120GB Western Digital to the original 40 GB which has been flawless. I may eventually add a second 120 if I ever run out of space again. I think this will likely work for the Tivo2 as well with excellent step by step instructions.
  4. Dave_Nich
    Aug 14, 2003
    12
  5. David S. Peterson
    Jul 7, 1999
    46
    3
    10
    Try for info.
    This site has a forum section devoted to upgrades. There are some issues specific to series 2.
    tivocommunity.com
    I have also just purchased from this place for a unit.
    weaknees.com
  6. Michael*K
    Michael*K Screenwriter
    May 24, 2001
    1,806
    I also picked up a drive from Weaknees a month ago. It was a pre-configured blessed drive. The instructions they included made adding the second drive pretty painless. Go here for downloadable instructions.
  7. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
    I upgraded 3 DirecTV receivers with TiVo (my own and two for friends), each from a single 40GB drive to a single 120GB drive using the Hinsdale instructions:
    http://www.newreleasesvideo.com/hins...to/index9.html
    I made a CD-R backup of the TiVo software for each unit and removed the original 40GB drive to keep as a backup. I'm glad I did, because my friend's new 120GB drive failed, but he was able to use the original drive until I installed a replacement 120GB drive.
  8. FrankC
    FrankC Agent
    Feb 26, 2001
    37
    If you want to save some time, you can buy kits which come with pre-imaged drives, the Torx screwdriver you'll need, an IDE cable, and detailed instructions at places like http://www.ptvupgrade.com/.
    I got a drive from them a few months back, took me 30 minutes to install, and the entire family has been quite pleased. Just in time for football season. [​IMG]
