titanic mk3 sub (1 Viewer)
cap765
gary
I have been going over the specs and find that this driver needs a much larger box more like 30913 cubic inches and 4 ports of a 6 inch diameter this set up should be good for 22hz if any one has built a smaller box with flat output to 22hz I would like to here about it this was a qb3 alinement thanks gary
Robert_J
Mississippi
First, what size Titanic were you looking at? I'm assuming the 15" model. No, it does not NEED a massive enclosure like that. I've seen 18's in smaller enclosures and tuned much lower with amazing results.
What program were you using to model this? Did you try to change the Vb and Fb of the design?
-Robert
hickskeith007
