Our old TV is finally giving up after 10 years, and I decided to get a RPTV (plasma is too much $$$ and LCDs scare me because of bad pixels). I am undecided as to which model, depending on several factors. Any shared experiences and input will be welcome.
1) Time Warner Cable - what format do they use for HDTV channels, how do their 'regular' digital channels look on HDTV, and how does the rest of non-digital channels look?
2) DVI connectivity - does it really improve picture quality over using component input? (and does TW HDTV box have DVI)
3) Sets - based on the comments here and from what I have seen in the stores, I am leaning towards the Toshiba 82 line (is HD basically HDX w/o DVI ?), Hitachi (SWX20B or UWX20B - are the extra $$ justified for SWX ?), or possibly considering a Mitsubishi which I believe displays 480p natively (if upconversion is a big issue).
4) Finally, how big? We'll sit probably 9-12 ft from the screen, so I am thinking 50-53". I am afraid anything bigger would just be too big.
- Honza
- Honza
