Time Crisis 2 question (1 Viewer)
MikeAlletto
My mom has bought Time Crisis 2 for the PS2 for my dad and me for christmas. On the back of the box it says:
If your playstation 2 computer system is connectedto your television with an RFU adaptor, component A/V cable orS-video cable, you will need to purchase an aditional connector. you need av adaptor scph-1013OU sold separately.
I'm connecting my playstation 2 with s-video, but I know my dad isn't.
Uhhh...what is this?
Jeff Kleist
The Guncon contains a passthru for an RCA video plug. The gun samples the video signal to greatly improve accuracy. If you're playing with non RCA, you need the adapter that was made for earlier PS1s when they went to the "one plug does all" thing
Jeff Kleist
MikeAlletto
Ahhhh...so I definitely need one for my setup since I'm using svideo, my dad won't need one then since he's just using the rca plugs to connect his PS2 up.
Morgan Jolley
How do you know you got it for Christmas?
This game was pretty cool when I got it, but I haven't played it in a long time.
Eric Alderson
This was a question on my mind today also. What I really need to know is will I have to switch between S-video and standard, or can I use the GunCon while maintaining the S-video signal? I don't want to sacrafice image quality.
MikeAlletto
From what I understand is this av adaptor thing gets set inline with your other adaptor. So for example the adaptor plugs into the back of the PS2. Then I plug my monster svideo ps2 cable into the passthru and then the svideo into your tv. Then you plug the gun video into the video on the adaptor. Is this correct? I looked on Link Removed in their accessories page and judging by what the adaptor looks like is how I think this works.
Chad Ellinger
Yes, that's exactly how it works. The AV-Multi Adapter (or whatever its called) connects to the AV-out on your PS2, and your normal PS2 AV cable (composite, S-Video or component) connects to the pass-thru on the adapter. You connect the Guncon to the RCA Video-out on the adapter. There's no loss in quality from using the adapter (as far as I can tell, and I'm using component cables).
JoeyT66
