Tilting RPTV
Discussion in 'Archived Threads 2001-2004' started by Dave Pobuda, Jan 8, 2002.
  1. Dave Pobuda
    Dave Pobuda Stunt Coordinator
    Dec 25, 1999
    82
    I have my Mits WT-46809 sitting in cabinet that raises it 40" off the floor. I love the extra clearance as I have 3 kids...But I am not viewing the sweet spot....as I raise up out of my chair I can see that it is much brighter. Was considering tilting the back of the set. Anyone ever try that ? Will it harm anything ? Access is not a factor as this cabinet is built into a wall with a storage room behind it giving me total access to every componet.
    Thanks in advance for your help.
    Dave
  2. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    There shouldn't be any problem with tilting the set itself, as long as you don't tip it so far that it becomes unstable (especially with kids!) Chances are, raising the back of the set an inch or two will do the trick for you.
    Also, if you keep anything on top of the set (trinkets) they might slide/fall off if you tilt it.
    KJP
  3. DougRuss
    DougRuss Stunt Coordinator
    Oct 3, 2001
    195
    Dave,
    I have my 46" Sony RPTV mounted into a wall on a stand (aprox. 24") and had the same problem. I used a few of those Rubber Doorstop Wedges,placed at the rear of the set.
    After a little tweaking(moving wedges in towards front of set) had it where I wanted it. Works great!!
    PS..... it doesn't take much of a tilt to get to the "Sweet-Spot". [​IMG]
