Ticker Tape cut off, Convergence?
Discussion in 'Displays' started by Tim Jin, Dec 21, 2003.
  1. Tim Jin
    Tim Jin Supporting Actor
    Jan 12, 2003
    529
    I have a Panny 47 and when watching sports in HD, like basketball, the bottom is being cutoff, where they show the score and time remaining of the game.
    What can I do to correct this?
    Tim
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    It sounds like you have too much overscan. You should adjust accordingly.
    (sorry, I'm not too familiar with RPTVs, so others will have to help as to how. Keohi is a good source of info, I'm sure theres info there on how to get into the service menu to adjust this (if this is not a normal adjustment).
  3. Tim Jin
    Jan 12, 2003
    529
    Does anybody knows how to adjust the overscan?
  4. Tim Jin
    Jan 12, 2003
    529
    TV guy is coming over tomorrow to correct the screen. Steve and I are on first name bases now. Due to my physical limitations, I can't tweak my set. Oh well, at least someone is making a buck [​IMG]
    I am assuming that it is just an adjustment. I will post an update later.
    Thanks Admins for keeping this forum going!!
  5. Tim Jin
    Jan 12, 2003
    529
    TV guy did his job and adjusted the overscan. It was at 5%-10% before. Now, its at ~2%. Finally, I can see the scores. Steve also did the convergence again for 1080I, 480I, 480P.
    If anyone needs their TV service in Orange County, I highly recommend Adam's Electronics in HB.
