Throw distance .. whats going on? (1 Viewer)
manxral
hanno miltova
say i have a question..
how come the optoma dv10 can project a 100inch image from just 11ft? :eek:
other projectors can only get about 70-72 inch from the same distance.
manxral
hanno miltova
i know that jim. but why? i mean if a throw range is factor with almost all HT owners , why create a projector that is less flexibale in small rooms?
Gregg Loewen
Founder, Professional Video Alliance
Insider
New England
Gregg Loewen
the throw range has to do with the viewing angle (or projection angle) of the lense. Think of it as a wide angle lense vs a telephoto lense. the wider the lense (for a short throw) the more distortion is added to the image. Or being said another way, it is easier to have less distortion with a long throw (telephoto) lense.
vasyear
