Threade Rod support?
Discussion in 'Archived Threads 2001-2004' started by Frank Kanyak, Apr 11, 2002.
  1. Frank Kanyak
    Frank Kanyak Stunt Coordinator
    Feb 28, 2002
    240
    Is it really necessary to use threaded rod support. What if I just Grizzly glue the endcap and silicon around the outside lip and then every 3-4" use .75 inch wood screws to fast the end caps? Would this be feasible?
    18" sonotube x 66" x 26" port
    Adire Tempest Driver.
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    The threaded rods aren't needed with an 18" tube. If the diameter of the tube was greater than 24"; they would probably be beneficial if the endcaps weren't made thick enough.
  3. Frank Kanyak
    Feb 28, 2002
    240
    Thanks. I can't wait to fire this puppy up!!!
