Doug_B
- Feb 11, 2001
Like to get some feedback on the difference in audio quality between having a fixed screen on the wall behind planar dipoles versus installing a pull-down screen and leaving it up during critical music listening.
I'll be getting a projector soon, so the fact that I'm removing a big TV from between these speakers will provide a discernable inprovement in the audio quality (I did use my audio setup for about 2 weeks prior to the TV being moved in and did notice a difference for the worse after the TV was in). I'd like to know if the back wall being disrupted by a screen would impact the audio quality in a noticeable way versus a (relatively) smooth wall between the speakers. The screen will likely be a Stewart Firehawk. The fixed screen apparently does come out a few inches from the wall due to screen and mounting hardware thicknesses.
My preference is to go the fixed screen route unless I can be convinced that a non-negligible improvement would exist with the screen rolled up out of the way.
Thanks.
Doug
Thanks.
Doug
