Allen Longcor
- Oct 21, 2001
For use strictly as a pre/pro. Well I was thinking of using one of them to power the surrounds, but for a strictly 5 channel setup with a 3 channel amp which one would you prefer?
I would certainly take a 'DA3ES over a 'DA2ES. It's a no-brainerKeith, keep in mind that the 3ES does not have DPL II or dts NEO:6. I would not settle for either the 3ES or the 2"ES" (really, it's the STR-DB1080). The 4ES or even the 5ES are the real gems. The 4ES even adds dts 24/96.
My point is that for around the same price, the 'DA3ES is going to beat the 'DA2ES soundwise.That's pure speculation,unless you've heard them at the same time?
However I would also choose the 4ES if I was looking for a Pre/pro right now.
You would be hardpressed to find a better equipped receiver/pre/pro for 1k or less[except for my 950].
