Thought I knew but now not so sure... (1 Viewer)
Phil
Ok I was really set on getting the HSU Enthusiast 2.. Then I found out I could get the the Enthusiast 3 in a 5.1 setup. But I am still VERY drawn on the whole horn tweeter and hsu vs svs. I have read and read and read about both and I was really set on hsu but now I am not sure. If I do go with svs it will most likely be 4 sbs-01, 1 scs-01 and 1 PC12-Plus. If I do stay on path with HSU it will be the Enthusiast 3. Since I can not listen to either I need advise from people who either have one of the systems or have heard either one.
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
You should listen to a horn speaker before you buy it. Some really like them and others, like me, do not. Have you asked HSU if there are any owners close by? Same thing with SVS. It is really best to listen for yourself.
webbhcjr
