Chris
- Jul 4, 1997
Tech Support Call Gone Bad
Probably.. well.. maybe.. not real. But very wild indeed!
Probably.. well.. maybe.. not real.Maybe? Probably? Try absolutely.
1) The snake would have had to willing stuck its head into a spinning fan blade. Unlikely.
2) It would then have to pass through an enclosed power supply without frying itself.
3) Having done that it would have to press itself through some thin air slots, which are the only points of exit from said power supply.
4) It would then have to crawl into the PC, turn itself around, go back through the power supply, stick its head in the spinning blades again and then electrocute itself. All the while being considerate enough to make sure its body would be entirely visible and easy to photograph once the cover came off.
Yeah, that happened.
Joe
The snake would have had to willing stuck its head into a spinning fan blade. Unlikely.Who said it was on when the snake went in there? It's entirely possible for a snake to crawl in there. Like said above, it's a warm dark place. Snakes being cold blooded are always looking for a warm place. My brother used to own a boa constrictor. One night it's heat lamp burned out and the snake managed to get out of it's tank... and crawl into bed with my brother's feet.
I don't believe the silly little story at the top.. but I don't think it's meant to be serious.
4) It would then have to crawl into the PC, turn itself around, go back through the power supply, stick its head in the spinning blades again and then electrocute itself. All the while being considerate enough to make sure its body would be entirely visible and easy to photograph once the cover came off.Who said it ever left the power supply? The pictures show an obviously fried snake in a power supply. At no time did it say the snake actually moved through the tiny vent holes into the computer case itself. Looks like it simply went into the power supply, hung out there for awhile, and was in the process of leaving when the computer was turned on.
This story is entirely possible.
At no time did it say the snake actually moved through the tiny vent holes into the computer case itself.But the other pictures show the snake's body neatly displayed inside the case, draped over the expansion cards.
See the comment on the "always hot power supply" above. Also the description mentions the hissing sound the night before when the computer was in use.
Joe
Also the description mentions the hissing sound the night before when the computer was in use.It says nothing about the computer being in use the night before. It just says "my computer was making a strange hissing noise last night."
I did not really pick up on the burn marks before, but there are several thats for sure.Now, that doesn't mean they didn't put an already dead (or even live) snake in an open power supply just for the thrill of frying it... but that snake did indeed fry in that power supply.
