This may not be the right spot but? (1 Viewer)
Joe Tilley
With HDTV how do you receive it? I know where I'm at you can get limited HDTV by sat,but it is my understanding you can also receive it from an antenna is this correct? I was wondering because I currently have a antenna that works pretty good for regular brodcasts & I'm thinking about getting a better one but I wont to be HD capable when I move into that,or it becomes available here.
Thanks for any help...
Bill_Weinreich
You can receive HD signals over the air with a standard antenna, although there are some specifically aimed at HDTV use. Are they different, i cant answer. But obviously unless you have an HDTV with integrated tuner, you will need an outboard tuner for the reception.
Bill
Brasspineapple
