This HT overkill for a 12x12 room? (1 Viewer)
Ricky_K
Grip
HTD Level 3 Y combo
Yamaha HTR-5550
Sony Wega 36 inch TV
is this overkill for a 12x12 room? Do you think the L3 X combo is a better choice?
Brian Fellmeth
Most of the people here, myself included, don't believe there is any such thing as overkill in HT. There are only weak links and upgrade paths.
Jeffrey Forner
Ricky;
My room is about the same size as yours. I have a 42" 16x9 TV. I have an SV subwoofer. I've used the HTD Level IIIs along with it. Believe me, you're fine. There is no such thing as too much. :)
Michael Lomker
I guess you aren't married, Dave. =) Not a day passes when I don't get hassled about the "fire hose" speaker wires and the square footage that my 5 speakers are using in the living room. I wish I had a big enough place for a separate "media room."
EmaxJS
Grip
The general recommendation is to sit 3 to 6 times the width of the screen (27' diagonal TV is 22' wide), Check out the viewing distance calculator on this site: http://www.myhometheater.homestead.c...alculator.html
According to it your Maximum Viewing distance for a 36" diagonal 4x3 TV is 12.5 feet since you probably sit only 10 feet a way (allowing distance from the wall for the TV and Couch) you are right on the money
steve nn
I tried the level 3 towers along with there center. I liked it very much. You sure can put it to those towers with out any distortion. They do a great job and if you move to a bigger room you will be ready. The center for the money is very nice to imo. :emoji_thumbsup:
Vince Maskeeper
I have a 12x12 with a 70 inch wide projection screen, Paradigm speakers all around, and a SVS with 1000watts behind it.
I wouldn't think your system would be overkill.
-Vince
Mike Strassburg
"I wish I had a big enough place for a separate "media room."
Michael,
Just keep upgrading& soon you will...it's called the garage!
Ricky_K,
Another thing to consider is how long you intend to be in that 12x12 room as what sounds good there might not fill the bigger room you move into in the near future. Better to over-buy now and have some headroom.
Speaking of headroom, I've got 9 towers and a dual Tempest in a 16x20 room, so even if she does boot me out to the 3-car garage I think I'm still ok :D
Ricky_K
Grip
thanks guys! Also do you guys recommend the HTD Level two's? For $499 I think is a pretty good bang for the bucks!
Ron-P
Ron
Ricky, I have a 10'x12' room, click on the link in my sig to check it out. Small rooms can make great HT's.
Peace Out~:D
linda19798888
